Hi guys, Just rebuilt my engine back to standard after snapping a valve with the carpenter set up. Ran gr8 for about 5 yrs time to slow down lol. Anyhow carpenter flashed my ecu to accommodate that set up but I want to get back a factory tune, any ideas I have the tune ecu but all the maps seem...
Thank you very much for your reply. My motorcycle is completely stock. If you could guide me with this problem, it would be a great help to me. My email address is volandosrl@gmail.com. Thank you again.
By your avatar picture it looks like a 2005. Do you know what tune code you have now ? If not, you can look at the sticker on the ECU. Typically the older bikes had 20050 and/or something close to that number. We can up-grade your performance with a modified tune. If you want to up-grade any of your exhaust or intake for some more output. If you are interested in that I and many other forum members have several exhaust up-grades such the TORs mufflers and cat eliminator and a plethora of aftermarket items.
I have been doing some research on the tunes for the Rocket III. What I can find about map 20228 is it is for aftermarket exhaust without a cat and aftermarket intake. I believe it would not work properly in a fully stock Rocket III. What looks to be for a fully stock Rocket III is map 20227. @Huron did you get the email I sent you ?
