TURBO200R4
stand up straight and grab the world by the a$$
has it got good volts at the solenoid (starter) ??
if u put extra wire on solenoid and touch to bat that would tell u problem is in solenoid/ starter or the wiring.
if u have a resistance prob the hotter it gets the worse it gets.(the more juice it draws)
i had this problem on an old gmc with headers. i finally put a ford solenoid on that put a wire from the bat to the starter. no more problems.
on my gmc when it would start it would barely move the amp gauge when it would not start it would peg the amp gauge so i would not hold the button very long or u might let the smoke out,
on the older ones the put the cat beside the starter i would imagine that would be the most heat.
i also have the extra ground,the 1.4 and the cat gone and a crossover. i have noticed that as the starter is breaking in the faster it turns over the motor
the next time i ride it i will check starting it when i get home we have some heat here
getting back to your shield several companies put a shield on their solenoids especially gm to keep the exhaust heat off the solenoid.
if u r getting the click (as in the starter is engaging ) what is happening is the starter is drawing the voltage down until the starter relay does not have enough power to keep it engaged.
hth
hth
