GIPro with arte?
Gear selection indicator, isn't it? Can be made to fool the ECU to use the 4th gear map (when in top) as 4th is unrestricted... I think
gear indicator + Advance Timing Retard Eliminator.
De-restricts the 7% the factory took away so we wouldn't hurt ourselves.
A plug an play unit that is worth every cent.
http://www.calsportbike.com/gipro/
I have one for sale in it's original box with instructions and brand new connectors. Red LEDs. $90 shipped to the lower 48
hogweed, the Advanced Timing Retardation Elinination fools the ECU into thinking that the bike is always in 4th gear, which has no timing retardation programmed in, thus providing the aforementioned power and performance improvements in gears 1-3 which do have programmed timing retardation built in via the ECU. It's like magic and it's probably the easiest and most affordable performance mod you can do on an R3, plus you get a nifty digital gear indicator, too. I did some other performance mods that render the unit inert performance-wise, so it's up for grabs. If interested, please send me a PM!
Thanks , would i be right in thinking i dont need one as ive got tuneboy with a custom tune (one off exhaust kn filter) ?
Yes, it would be of no value to you other than for the gear indication function. That and the shipping to you would be a real mutha'!:whistle:
Yes, that is amongst a number of "tricks" the factory employs to restrict the true power which lies within the belly (engine and exhaust system) of this particular beast, Paul.:twisted:
