Front wheel from '08 fit my 2016?
Discussion in 'General Tech Talk' started by CvSisinthehouse, Oct 3, 2019.
Tags:
  1. CvSisinthehouse
    CvSisinthehouse .060 Over
    160
    Featured Threads:
    14
    92
    38
    Silver Spring, MD
    I am looking to get another front wheel, will a 2008 one fit my 2016 Roadster? Thanks.
  2. Fingers
    Fingers Living Legend
    2,731
    Featured Threads:
    4
    1,501
    823
    Ocala fl
    Ride:
    2015 R3T
    It would fit but pretty sure you’re abs ring will bolt on
  3. Paul Bryant
    Paul Bryant Living Legend
    Country:
    New Zealand
    2,807
    Featured Threads:
    45
    6,066
    823
    Hamilton. New Zealand
    Ride:
    2006 Rocket
    The Roadster has the axle inserted from the opposite side.
    I'm not sure if this would make any difference.
    Are the bearing size's the same both sides ?
  4. cootertwo
    cootertwo Top Fuel
    Country:
    United States
    1,528
    Featured Threads:
    29
    Media:
    4
    2,532
    323
    Labelle Florida USA
    Ride:
    2013, & 2 05's R3R, 2006, 2004 Harley's, 2004 Kaw
    At some point in time, Triumph changed the front wheel for some unknown reason. Look and see which side the axle goes in from. The seals are different on each side. Either wheel can be used, but may require swapping the forks from one side to the other. And of course you need a new enough wheel, that it has the mounting face for the ABS ring to bolt onto. I have a 2013 wheel on one of my 05's, no problem, just switched the forks around. Not sure what year ABS came out.:)
    EasTexRIII and ozrider like this.
  5. TURBO200R4
    TURBO200R4 stand up straight and grab the world by the a$$
    Country:
    United States
    4,850
    Featured Threads:
    7
    4,037
    823
    TUCSON AZ
    Ride:
    07 rocket III classic
    wouldn't that put the brakes in the front of forks?
  6. scot in exile
    scot in exile Living Legend
    Country:
    United States
    8,650
    Featured Threads:
    201
    11,548
    823
    Fort walton Beach FL, Glenrothes Fife
    Ride:
    2005std, 2011 Carp Roadster, 2001 Tri Adventurer,
    Pretty sure it was 2010 when ABS came along for the Roadster
  7. cootertwo
    cootertwo Top Fuel
    Country:
    United States
    1,528
    Featured Threads:
    29
    Media:
    4
    2,532
    323
    Labelle Florida USA
    Ride:
    Wheels will switch no problem, however to keep the wheel turning the right direction, swapping the forks may be necessary. The fork tubes are the same, the seal on the side of the wheel where the axle slides in from, is larger than the seal on the other side. You almost have to have both in front of you, to understand the difference.
    Tripps and ozrider like this.
  8. Tripps
    Tripps Retired superhero
    Country:
    United States
    6,519
    Featured Threads:
    35
    11,157
    823
    Florida and NY
    Ride:
    R3T,Sprintona,K1200GT, Blackbird
    That would be a batch if the front wheel turned the other way for sure.
    :confused:
    Jag likes this.
  9. breeze
    breeze Living Legend
    Country:
    United States
    2,935
    Featured Threads:
    9
    4,138
    823
    bloomfield n.m.
    Ride:
    07 classic/01legend/72 bonne
    just mount the tire backwards
    Tripps likes this.
  10. warp9.9
    warp9.9 Pocałuj mnie w dupę
    10,154
    Featured Threads:
    9
    Media:
    14
    12,124
    823
    Forest City Illinois
    Ride:
    07 Rocket
    @1K9 , could probably shed some light on this as he installed a roadster front (correct direction of rotation) on his 2007 classic tourer .
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
