Carms4321 Standard Bore Joined May 3, 2025 Messages 3 Ride 2007 rocket May 3, 2025 #1 My front engine main bearing is walking forward. Wondering if it can be replaced by removing lower section of engine Also is this a weakness in this design Or Wondering what might have cause it to fail Thanks
Tripps Retired superhero Joined Oct 9, 2010 Messages 11,940 Location Florida and NY Ride R3T,Sprintona,K1200GT, Blackbird,r/65 hack May 3, 2025 #2 I can't remember ever hearing of a bearing failure before
Carms4321 Standard Bore Joined May 3, 2025 Messages 3 Ride 2007 rocket May 3, 2025 #3 Was quite surprised when I found it Started making some noise, plus the oil pressure was bit erractic. Hoping to slip a new bearing in from underneath. The rest of the motor was doing fine
Kevin frazier Widowmaker! Joined Dec 22, 2018 Messages 8,387 Location Nashville Ride 2008 Triumph rocket 3 touring May 3, 2025 #4 I assume you are referring to balance shaft bearing? Case has to split. Erractic oil light means something is wrong. Post a picture of the bearing.
Carms4321 Standard Bore Joined May 3, 2025 Messages 3 Ride 2007 rocket May 3, 2025 #5 Kevin frazier said: I assume you are referring to balance shaft bearing? Case has to split. Erractic oil light means something is wrong. Post a picture of the bearing. Click to expand... Yes I know case needs to be split Bearing is directly behind lower timing chain gear
Kevin frazier Widowmaker! Joined Dec 22, 2018 Messages 8,387 Location Nashville Ride 2008 Triumph rocket 3 touring May 3, 2025 #6 There ya go, youre on it.
