mjbell1
My 07 Classic Touring is equipped with the standard heel and toe shifter. Which to me is a pain in the ass, being accustomed to just a toe shifter. If you need to use your heel to down shift you've got a problem somewhere. Dwelling on the problem the other day I remembered that I had picked up a universal toe shifter in case of breakage on the dirt bikes. The shifter other than not being chromed was a perfect match to the shape of the toe section of the shifter. Installation would require removal of the complete toe/heel shifter linkage. Installation of the toe shifter would go directly onto the splined shifter shaft at about a 45 degree down angle. Would also need to make a cover for the previous bolt hole. Has anybody ever tried this mod, results good/bad? All replies gratefully appreciated.
