barbagris
Mad Scientist
- Joined
- Aug 1, 2010
- Messages
- 12,988
- Location
- On the verge of insanity
- Ride
- 1979 Guzzi V1000G5 - 2018 KTM 790 Duke
When your dip headlights are on there's a horizontal "line" above which there's no light. i.e. light above this line is CUT OFF.What do you mean by "dip cut off"?
In reality it's reflected or refracted to somewhere else - normally down onto the road. Without this you'll dazzle anybody coming the other way.
Most of the cheap LED lights out there are defined as OFF-ROAD or WORK lights. They emit a cone of light forwards. No redirection of light - just a homogeneous cone.
The better fog and driving lights don't cut light off . They also use lenses or reflectors to focus the light correctly to where the light needs to be.
The TRIUMPH FOGS literally CUT OFF - there's an aluminium plate that blocks off 50% of the light (the bit that would go up.
Many cheaper Polyellipsoidal (bullseye lens) lights do the same btw.
My converted Triumph Fogs retain the plate - the driving lights do not and the light source repositioned so they emit a VERY narrow beam.
A LOT of the E-Bay specials are in fact FLOOD beams - 45º - I've seen as wide as 60º - This reduces throw or range.
A SPOT (driving light on vehicles) beam is generally in the region of 20º, LONG RANGE closer to 7º or 8º
There are some interesting LED headlight reviews and comparisons at www.bogiesreviews.webs.com
