The dyno says max torque at 3200 rpm 145.5 and max power a 6400 rpm 135.8 when I figure out how to put the page up here I will or I will email it to some one who can
That's way more than I'd expect on stock air intake/Dealer tune esp as stock tunes cut the fuel over 6300revs:shock: That a real wheel measurement or flywheel figure? If it's rear wheel then you've done really well.:grin:
I'll bet you don't get 120 at the rear wheel. Lots of angular loss between the trans and rear end. It's really the torque number I'm interested in hearing about and seeing the torque curve.
If you could post the graph, Axel, that would be great. I owned a 104" Harley stroker that made 112 HP and 108 ft/lbs which felt stronger than the r3 but it also weighed 150 lbs. less and had a boat load of engine work.
I'd also love to put my Boss Hoss with the 383" stroker motor up but the dyno here is too short and the ground clearance is so bad that it would be a bear to get up even if it did fit.
I'm going to put my r3 Classic on the dyno in a week or so. Jars, K&N and PC III. Feels great but the dyno is a cruel truth teller.
Thats rear wheel and as soon as can figue out how to get the page scanned in to my puter I will send it to warp to post for me cause I am not a tec savy guy LOL
The sheet
Still impressed with that result considering the only mods are pipe & Triumph tune, but I see your Torque crashing beyond 3.5krevs.( down to 130 @5krev& falling)
Triple K&N & Tuneboy will not only give you more everywhere, but mine is holding a flat torque line of 150+ from 3 to 5&1/4K revs.. Its a big difference for not much money & you could have it easily.
