Willtill
Nitrous
TORS tune done by dealer. Mods are TORS, staintune crossover collector, secondaries removed, GiPro with ATRE, tripple K&Ns (tripples fitted at same time as Debec). I didn't remove the O2 sensor. Although it was running fine I was definitely running too lean before; lots of decel popping especially and not idling too well when cold.
Thanks for the info. Am sort of undecided on where to start regarding a tune (should it be a base tune or modified - such as yours) before I install and begin to adjust the settings on the Dobeck.
I currently have installed the 3 K&N's, triumph cat delete bypass, stock OEM silencers and have removed the 02 sensor with the dongle. At the moment, I have loaded the 20145TuneJardinesFixed tune. I haven't taken her out yet for a run, since I am patiently awaiting the arrival of a Predator exhaust from Sam. Then my Rocket will be finally completed for intake/exhaust modification and I hope to get her dialed in proper, and checked for A/F ratio's on a dyno locally.
