Chrome is best chemical removed and I'm not sure if the chemicals are available for home stripping . I would not reccomended blasting chrome as altho this will remove it , the whole component will then need re polishing before the copper base coat , nickel coat and then chrome coat is applied thru electrolysis ! Blasting with fine medium is ideal for painted surfaces tho as it provides the perfect key for your paint ! Most platers will prep and plate reasonably inexpensively !
