nolton
@nolton
Any tire is designated by cross section length, sidewall aspect ratio (percentage) and mounting diameter. A Stone Excedra Max is 240/55R16 means 240mm cross section width - the 55 is the sidewall aspect ratio (55%) - the "R" is radial - the 16 is wheel diameter in inches. Go figure this! Inches and millimeters used together?! WTF???
If you multiply the section width value by the sidewall aspect ratio you get the sidewall height. So, 240 X .55 = 132 mm 132 mm X .03937 (conversion factor for mm to inches) = 5.2 inches.
Now since there are two sidewalls in the total wheel diameter take 5.2 X 2 = 10.4 inches. Add this to the 16 inch diameter and you have a 26.4 inch total diameter.
Let's compare to a stock Metz 240/50R16. 240 X .50 = 120 mm. 120 X .03937 = 4.72 inches X2 = 9.45 inches + 16 = 25.45 inches total diameter or .95 inch smaller in diameter than the Stone.
Calculating a car tire is the same. 225/50R16 would be 225 X .50 = 112.5 mm X .03937 = 4.43 inches X 2 = 8.86 inches + 16 = 24.86 inches total diameter.
Hope this helps and I didn't screw up any math.![]()
No that don't help at all!
