Crazy ignition skip under load
If you leave the flat plate off the number one coil the coil becomes accessible. All the plate does is hold twice wire connector mounts. With out them the wires will still lay in there like they are supposed to. The only difference is you'll be able to access the #1 coil . The connectors do vibrate loose cause they are cheap. A little squeeze with needle nose pliers and the are snug again. Probable tighter then factory so you won't have to fart around with them again. As for the high tension leads. Park her outside at night in the dark fire her up and look for any wondering sparks
nice to know about the plate, spare parts it is, I was thinking about changing all of connectors out to better ones, but i can check the crimps again, and never thought about looking for the sparks at night, great idea, and i was thinking about going back to the original leads and see if that changes anything, if not then i think that will push me into the direction of coils.
I have some used coils if you are interested
$125.00 plus shipping
yes, I may need them, let me check with my shipping broker to find out what kind of nightmare it is going to be to get them shipped across the border, it may be easier to have them shipped to a facility in Rochester NY, Buffalo area and pick them up, some things are easy to ship over, and some things are insane
FWIW you can swap out the coils to overhead coils for under a few hundred bucks...
thought about that, but I believe I need specific R1 coils that are about $120 each here, plus the connectors, so cost wise it works out to almost the same as buying Triumph coils
yes and no...
If you can get these on amazon with the connectors is about $100 or less if you have prime.
Its all about the ohms.... there are various coils that work.
and BTW the triumph coils are literally any coil that has the same ohms from nearly any motorcycle since the 70's aka JUNK i have piles of them from various projects and they are all worth NOTHING unless a sucker buys them... i suggest you do not.
they are showing 4 coils for $35.00, i would be leary about that, if i'm going the over plug way, i would be probably go with OEM coils, I have had issues with some items made from Chineseium and Fallapartium from Amazon
