Hemi_Guy
Hey all,
2011 R3 Touring
I changed my spark plugs last night and put everything back together, it was late so I didn't bother starting the bike until this morning.
Turned the key and everything lit up as normal, hit the starter and I heard a short click as though the starter wanted to engage then everything blinked out and came back on as though I just turned the key, hit the starter again and everything went dead and stayed that way.
I went through the electrical the best I could, battery, fuses, reconnected everything under the tank that I touched, check pins in connectors, checked for pinched or cut wires, bypassed my Power Commander, nothing. Complete electrical failure, even accessory circuits.
I confirmed power was present at the fuses, especially the 30A that feeds the ignition switch. Pulled the ignition switch and opened up the bottom, nothing looked melted, grabbed the multi-meter and checked pins with switch off then on, everything seemed to make connections as seen in the electrical diagram for the bike.
I can see multiple threads discussing Ignition switch failures but I could use any insight you may have.
Three weeks into this bike and this, not happy.
Thank you,
Paul.
2011 R3 Touring
Thank you,
Paul.
