RockOn
Turbocharged
- Joined
- Feb 22, 2018
- Messages
- 551
- Location
- Escondido, CA
- Ride
- 2006 R3 Classic, 2008 R3T, 2009 Harley Ultra
Stopped for gas at a station near my house before heading out to meet with fellow retirees for our weekly ride. Finished pumping gas, switched the key on and my '08 Touring's ignition was deader than Julius Caesar. Pressed the horn button and my air horn blasted loudly via it's separate circuit, so battery was fine. Fiddled with the clutch, kickstand, kill and key switches with no luck. Then I remembered the exact same thing happened on my '06 Classic a few years ago when turning the handlebars too far one way or the other, causing the burned and/or corroded ignition wire harness connectors to lose contact . I fixed that problem with De'cosse's keyless ignition. When I bought the Touring model 6 or 7 months ago I decided to remove the keyless unit from my '06 Classic and have Ken repair the original ignition switch plus make a wire harness that would allow his keyless unit to connect to the '08 Touring model.
I was under the impression from information I have read on the forum about ignition switch problems, at least on older Rockets, that the Touring models had a better electrical design concerning the ignition and it would probably not fail. So I decided to put the keyless unit on the shelf and hoped I might not need it for a very long time, if ever. Well, "if ever" arrived today, so I will be installing the keyless unit in the near future. I should mention that Ken also advised me how to add a relay to the starter relay on my '06 Classic to fix the faulty Triumph design which causes the ignition switch failure(his design diagram is posted somewhere on the forum). I did that relay grafting surgery on my '06 Classic after reinstalling the ignition switch that Ken repaired. I don't think this additional relay will be necessary after installing his keyless unit on my Touring model but I will double check with him on that.
PS After remembering the same problem on my '06 Classic I turned the Touring's handlebars to the full stops both left and right several times in hopes I would get the ignition harness contacts working......ignition turned on and the bike fired up instantly as always.
