Can someone please post a picture of where I can locate the crank angle sensor. I am doing an oil change and thought i would clean the sensor at the same time. Also what oil are you using in your rocket.
Ah no. Now you've done it. With this group, you're going to get every concoction listed from corn oils, to scented lavender body oils.
Personally, I pay up and use Mobil 1, 4T full synthetic 10W40. You will notice a definite difference in shift smoothness using this stuff, even after several thousand kilometers. I've found that with other oils, the tranny starts to feel snatchy after you've ridden on it for a while. The Mobil not nearly so much.
