I recently began hearing a slight miss in the exhaust note like a cylinder not firing right and transmission gear whine changes with the exhaust note. Mostly at very light throttle light acceleration. I am checking vacuum hoses and throttle body seals along with all other adjustments, TPS ect. I thought if I checked compression I could rule out internal engine problems such as valves and I would know the engine itself is ok and the problem is external.it's not a dead miss, more like one cylinder just not hitting the same as the other two.
