berrypicker
crank it over with a volt meter across the lt connections on the bad coil if thats ok check the ht side could be jumping to earth down inside the spark plug tunnels ,for a temp fix bind the long plastic connectors ,the ones that push on top of the spark plugs ,with a couple of layers of pvc tape do both as one shorting will cut the spark to both plugs
