Bukwas
Standard Bore
Hello All, this is my first post here so thank you for your time!
I purchased my R3T August '08 (VIN#8J344024) it has 2603 Miles. When I received the bike I took it for a ride and found it hard to find neutral and it didn't seem to want to downshift from 2 to 1. Occasionally it would drop out of 1st when shifting from neutral. I also felt a vibration in the floorboards and handlebars that didn't seem right. I called my dealer and was told that "they act-up during the break-in and after the oil change at 500 it would smooth out." When I brought it in for the 500 mile check, I let the mechanic know I was still having problems with downshifting and neutral was hard to find. I felt like the clutch was not fully disengaging. With the clutch engaged in any gear you could pull very lightly on the clutch and it would eliminate the vibration I could feel in the floor boards. The dealer adjusted the clutch so that there was no slack in the cable and slightly pulling the clutch in. With the clutch engaged in any gear you could pull very lightly on the clutch and it would eliminate most of the vibration I could feel in the floor boards. At 670 mile I got a screw in my rear tire and brought it into the dealer tot be replaced. I let the mechanic know that the vibration was still there and had not changed much. I also felt like the adjustment was going to be bad for the clutch if it was slightly pulling on it. He then adjusted it back to the way it was originally. At 2600 miles I was riding with my wife and pulled in the clutch to shift and I felt the resistance of the clutch drop off and the clutch re-engage. The only time I could shift was when there was minimal load on the engine and I could power shift. I played hell getting it home trying to time lights and just rolling through 4 ways. I stalled it on my lawn and slide to a stop. I am so happy that nothing happened to my wife or myself. Except for the vibration which until recently, I attributed the 2.3L engine, the bike has been great until this failure... I have them picking my bike up on Tuesday. Hopefully it is a simple fix in the clutch basket. What kind of contamination will this failure send into the engine and what should be cleaned during the repair. This is the first new motorcycle that I have bought and believe a total failure like this at 2600 miles is unacceptable let alone the unsafe nature of such a failure.
Thanks,
Bukwas
Thanks,
Bukwas
