Carpenter Racing Exhaust
Yeah you have pretty much summed it up there,
for a stock or mildly tuned motor stepped headers can help avoid the dead air at lower rpm WOT,hard riders would of course just downshift & rev its wotsits off. As usual horses for courses :)
I been asking lots of question to the guys that make header systems and here is the low down as I understand it.
I am not saying this is 100% accurate but my take on the info I have gleaned from several reputable bike and car tuners plus info I found on the Net, No Arguments will be entered into by me
a 2 inch system is more suited to forced induction and highly modified R3 motors and on a non internal modified motor will only give benefit at high RPM where most of us do not go or otherwise not spend a lot time there, so yeah a Carpenter exhaust system is great if you are running Hi comp Hi reving cam profiles in eg carpenter 240 kit worked engines or are running a SuperCharger, in other words it is designed to work at higher revs or move large amounts of exhaust to work at its best, it will still work on a std engine but not as efficiently as a slightly smaller OD header (something about loosing velocity in the larger OD)
a 1 3/4 system will suit a stock engine and give benefits to it offering good scavenging and good all round performance but if you then wish to go to hi comp pistons and cams that work in a lower rev range eg Ponters bike with his Neville lush worked engine and Reband exhaust it will then be working at it designed level
a 1 5/8 system again will suit a Std engine and also some slight mods but not a lot more unless it is a 3 into 1 system with a decent size choke, then it has more potential for a modded engine
Again I am not looking to start an argument just stating the fact that I have found to help someone trying to decide which size/type exhaust to buy for their bike :)
Not to bust anyones arse or bubble but can you explain why when Bob Carpeter put a set of his pipes on a bone stock R3T he pulled 165 hp and 163 in torque?
He had to have used a different map surly - probably an optimised Roadster map? with 100% secondaries?. Just guessing. I don't know.
R3T owners who swapped maps on standard zorsts have seen power increases too if I recall correctly. Didn't pred's give similar figures on standard engines too.
It's annoying - I had all the formulas for this sort of stuff but lost them when I left the UK in 1990. Resonance, volume, velocities - waveform shifts. I've heard about some interesting results using vanes to spin gasses - but blowed if I can find any proper documentation - White Paper type info - not marketing. I'd love something along the lines of that bellmouth article.
Secondaries really don't matter to Bob as he takes them out and tosses them. He hid have a expanded map so he could go to 7500 rpms but other then that all the tunning was done with PCV. Bob does not use a gas annylyzer he tunes for max power takes it up with fuel until it noses over and then brings it back. The same way he tunes all his bikes. I will also add that this was done with the OEM velocity stacks and no filters. As Nev has stated there is three settings on a dyno which will yeild three differnet hp readings and like Nev bob uses the middle one which seems to be the norm. This is why he can send one of his bikes from New Jersey down to a independant dyno shoot out in florida and yeild within a horse power or so of what he gets on his. I wish someone close to him would take a older Rocket to have it tuned with the pipe as it would make a excellent base mape for Gracie.
Hey Warp..........
Isn't 150-160 RWHP the "norm" with triple filters, decent exhaust like Preds or Reband, say 1 5/8" - and a good tuner?? Leave the filters off and might you expect 165 or so.... even without the big-bore Carp pipes??
Hey Warp..........
I met a guy at my dealer with an R3T with Jardines and triple filters who had his PCIII tuned there to 157 HP. My bike got 140 hp on the same dyno with TORs/cat bypass and a Wayne McDonald tune.
Hey Warp..........
Ruzz I am not the one to ask. I would ask Nev. I trust what he says like I trust what Bob says. the question is when the preds were dynoed what setting was the dyno on. Bob could have chose the that would have produced more power but he went in the middle like Nev uses. So without knowing what setting these 155 hp preds readings were done on I could not say. In fact I would not say. I do believe in th etheroy big in big out. increase the air flow in by means of tripple filters and addd big exhaust I would suspect larger numbers. The one thong I know is Bobs dyno numbers on what ever bike he tunes seems to match other independent dynos. I have not seen such a comparison with the preds. What I will say is this looks like its heading towards a argument and that is not something I joined the site for. So I will now just sit by the side before it gets blown out of proportion.
