Brake Lines & Cables
I am lost fellows, this is the reponse I got From Barnett, so where do I find a 4 inch longer brake line. Will all the Thunder Bird cables fit, I see that they are about 3 inches longer, anyway I want to order this stuff, but I will not be home for a month. Does anyone know the lengths of the Roadster cables, I will just order those from Barnett, and look for the brake cable. It's going into the shop for this, I do not have time to do it, so I need the cables before I take it to the shop
We are unable to do the brake line. It has ABS and needs a special block which we do not have.
There is no problem making the other cables in any length you need. In black casing, special length cables
would be $163.00, this would be the throttle cables and the clutch cable. I checked the other source
for Triumph brake lines, Speigler, and they also do not make this line.
When you determine the length you need and are ready to order, our sales desk will assist you.
I am lost fellows, this is the reponse I got From Barnett, so where do I find a 4 inch longer brake line. Will all the Thunder Bird cables fit, I see that they are about 3 inches longer, anyway I want to order this stuff, but I will not be home for a month. Does anyone know the lengths of the Roadster cables, I will just order those from Barnett, and look for the brake cable. It's going into the shop for this, I do not have time to do it, so I need the cables before I take it to the shop.
Here is there response.
