Auxilliary Lamps Kit - help!
I had another look under the tank today and after a lot of searching & digging about I eventually found the correct 3 way connector!
It was well hidden under the main loom on the right hand side about half way along the tank.
I found another two way connector in there in addition to the heated grip connector so the schematics are not all that accurate.
Connected lights and indicators up and everything works as it should.
Once again many thanks to all who replied.
David
Reactions: idk
Pleased you found it & all is now good!
The two way connector IS actually shown on the schematic - that is for a GPS - should be another Econoseal I believe?
And the main accessories (2-way) connector also
So there is definitely error on the aux lighting connector on schematic which should also show a ground.
