R-III-R Turbo
Mine is the biggest :)
- Joined
- Oct 12, 2010
- Messages
- 2,502
- Location
- Ireland
- Ride
- 2472cc Supercharged Carpenter Rocket III Stroker
good point, but not sure if that would stop the Auto Tune from working, I thought that was just to keep crud out
While it all looks right you do not have the Can terminator plug fitted and I just went out and look at mine and the plug actually has a little resister in it so it does actually serve a purpose as R-III-R Turbo indicated (sorry I doubted you R-III-R Turbo)
no probs. leaving the terminator plug out gives the same symptoms as described.
i only know this coz i put wideband 2 module (basically AT with a gauge or LCD) in to replace an AT, there was no CAN plug with the WB2 kit. so i didnt use one. and the AFR reading etc would not show up on laptop. CAN plug fixed it. (shame on dynojet for not including it)
And, I put the little plugs in both the PCV and the AT unit. No change.
dynojet told me only one plug is needed, in either the PCV or the AT. cant remember if they specifically said "dont" use a plug in both.
