I'll give Anti Gravity the endorsement as best LiFePO4 maker of the three.
Is it really LiFePO4 Rob? - Because that is important. Most that say Lithium-Ion do so because they cannot put LiFePO4 on the box.
The CCA rating thing is pure bollocks if the chemistry cannot work. My Lithum in the R3 (bought because the LeadAcid died on holiday) is NOT LiFePO4. It needs warming after sleeping overnight in my mums garage in UK spring. When warm it'll crank the LandRover over.
The Lithium in my Guzzi is LiFePO4 - has a bit less kick when warm - but operates to much colder temps. I made this myself.
Wish A123 still made the big 8aH cells - I'd make more and I'd make another 16aH beast - That belted out a kilo-amp, burnt out a starter motor (oops)
Note that all Li I have seen so far have one common "issue" they do NOT like to be charged subzero (Celcius).
That sounds fine until you realise that the engine will be charging the battery.
I keep my jump box (Genius 7000 Joule) inside so it's never cold. My mate Jim kept his Anti-Gravity Jump Box inside his Jacket.
If I were further north and more susceptible to cold - tbh I think I would go back to LeadAcid and simply carry a small LiFePO4 booster.
Live somewhere Hot: Lithium of any sort. Fit and forget.
In between - Think I would retry the parallel system used by
@warp9.9 - Tried it here but along with the summer temps it was killing lead acids off really fast. Though tbh it would be totally unnecessary.
One thing I do like is 4 post batteries.
