barbagris
Mad Scientist
- Joined
- Aug 1, 2010
- Messages
- 12,988
- Location
- On the verge of insanity
- Ride
- 1979 Guzzi V1000G5 - 2018 KTM 790 Duke
OK - girded on by Rob's Pipercross - decided to refit a custom ITG filter made by Colin (who once posted as Battersea). It is a top level filter with anti flame internal mesh as well as normal shaping wires. I'll bet it was a small fortune to have made.
It uses the Triumph rubber "bellmouths" - it was the predecessor of the design later done by Colin which RamAir were given unlimited permission to make and sell.
I took it off as it has a VERY FCUKING LOUD intake roar - (it drowns out the open and short THUG exhausts and any wind noise/police sirens etc - even at very high speeds). But also (more worryingly) because my pants were rubbing the foam.
1) the foam was going to wear out.
2) my missus was getting annoyed with the oilstains on my trousers.
It will NOT fit under a BearClaw.
So today removed the OZ-Claw and found how much of the filter foam is actually pressed against the sound damping foam inside the OZ-Claw. It is a lot of lost filtration surface. - Note that with a normal bearclaw - there is no sound damping foam so this surface is not obdurated.
All that hatched out area is not functional - The thingie behind is a heat wall and air flow addition so the filter gets ALL the air from the OZ-Claw opening blasted down onto it. The rear surface is fully exposed and filthy. The exposed surface was covered in seed, dirt, bugs etc. It's been on about 2 years with no maintenance - including two Spain-UK trips.
Offered up the ITG with its special cutaway claw bit (made by a friend here in Spain) - with a mesh added for wear resistance.
The red circle is where my pants rub. The straps are just holding the mesh in place whilst i get the position right. It's stainless steel mesh and is a bugger to form around the domed end. Patience!. When I get it right the mesh will be screwed to the aluminum backplate and thread locked in place.
Whilst it almost certainly offers SOME airflow restriction - I think I am going to cover as per the photo rather than just the bit my knee rubs.
Will it stay fitted? - depends on a few factors. But a big one is whether I can live with the noise.
