If that reading is correct and I have no doubt it is, is your bike a bit rough at idle and low throttle because that is saying your throttle bodies/ plates are out of sync
Oh and what @Pedro is saying is 100% correct you need to adjust you balance by adjusting the two balance screws, 1 between 1 and 2 to bring 1 in line with 2 and adjust the screw between 2 and 3 to bring 3 in line with 2, I would also be doing a check to make sure all the throttle bodies are sitting in their rubber boots properly because that is a long way out, have you had any back firing
I would definitely be checking that balance out thou that is the biggest difference I have seen, try hooking it up again and see if it gives the same sort of reading and maybe just play the throttle up and down a couple of times as maybe it was just hanging up on one of the linkages
If there was a leak through any of the ports, the pressure would be HIGHER not lower. (lower number means 'better' vacuum) i.e. #2 is pulling LESS air than 1 or 3.
The numbers don't so much suggest leaks, just very poor balance (or lack of)
