DEcosse
If it's no Scottish it's CRAP!
however. tune ecu readings start at 0, when bike is not running, which means that the readings shown are 'gauge' readings i.e. not absolute.
when you idle the engine the needles float about 600hpa (should be -600hpa if we are on the gauge and not absolute scale), and as you rev it up they get closer to 0.
having that - in front of the numbers would correct the readings to actual throttle pressure readings (on the gauge scale tune ECU uses), but the readings would not be raw readings as raw readings would be on the absolute scale.
tune ecu must do some simple maths to change the reading from 400hpa (absolute pressure at idle) to display the 600hpa. but of course it should be -600hpa to be correct.
That is incorrect
The simple reason that it displays 'zero' is because the engine is not running - there is only one single sensor and the software times the display measurement in concert with the cylinder on the intake to direct that reading to the appropriate display 'gauge'; i.e these readings are not constant per cylinder, each 'gauge' is only being updated by the software to report as the timing of the crank dictates - engine not rotating, there is no update to the display for any of those cylinders.
The pressure readings ARE absolute.
