Status
Not open for further replies.
What kind of device have you that runs Android ?
The LonElec cable will have the OBD2 connector and required electronics to talk to your bike's ECU.
The cable has a USB connector, and you will need a USB adapter cable to go from the end of the LonElec cable to the charge/data port of your Android mobile device.
Since LonElec says they are open normally, and shipping, please contact them directly, and tell them you have a bike with an OBD2 interface, and what kind of phone/tablet you have, and they should be able to tell you what you need to order. Pretty straightforward and inexpensive as these things go, and they're in the same country as you.
As @EwoutR3 said, using your mobile device, go to PlayStore, enter "Tunecu" in the search bar, purchase and download.
Once you have the cable and adapter, hook up a battery tender to your bike, remove the left side cover (or remove the seat) to expose the OBD2 connector -- it's the only one that looks even remotely like that), and then come back and talk to us.
Whilst I'm waiting for their reply:
Does it have to be that particular brand? There are many on eBay with decent delivery time. Does it have to me for R3 certain year or not really?
I have both : Windows laptop and Android tablet+ phone.
I purchased mine off eBay -- but yes, it needs to be that LonElec brand.
Your Android tablet is what you need - PlayStore, purchase and download TunECU.
Lonelec works fine, the others I have no experience with. The link above, the cable comes with an adapter for your tablet/phone. So you can use windows (free) or the android version of tuneece (cheap).
Unplugged the battery for half an hour then went for a ride. ABS light was off until stopped and after starting ignition it stayed on for the whole duration of the way back. Strange
Yes, you can. Just be a little extra careful to avoid panic stops - wet roads, etc.
Please keep us posted.
And if you get bored while waiting, ordering the LonElec cable, and TuneECU on your mobile device - is simply not that hard, and we'll walk you through it.
I seam to remember something about tune ecu can it read abs codes?
maybe something about bleeding abs braskes
Status
