ABS fault light on
Oldman68
South West UK
2012 Rocket Roadster Red Haze
Hi. My 2012 Roadster has got a ABS fault light come on this week and I have checked over the bike and have found the front ABS cable next to the head stock has been squashed and I think that by turning the handle bars to the left somehow the cable has got caught when on full left hand lock. My son who's a mechanic and has a multi meter is going to check the sensor cable but want to know what sort of values volts/resistance the sensor should be putting out if ok. I have found where the cable connects to the main harness on the L/H side under the tank. Does anyone know !.
I managed to trace the ABS fault down to a crushed cable after testing it with a multi meter so then went to find how much this will cost to replace and found Triumph asking £125.00 for the part + fitting it. So decided to see if I can find a second hand sensor but no luck there, I did find that both front & rear sensor are the same item then I found that these sensor are the same as the Triumph Tiger 1050 Sport front only by cross ref the part No. so tried again for a second hand one for this model and these are easy to find luckily. I got one for £17.00 on ebay and job done.
