ABS light
Have you checked you have the sidestand fully up - it has a lock out switch to prevent running with it down or even possibly ajar. Also the clutch has a cutout switch near the hand grip that must be engaged if not in Neutral when starting by pulling in the clutch lever. Obviously there is a cutout switch for the neutral position as well. You can start with bike on sidestand or sidestand down but it must be in neutral.
That was it! Thanks for the answer. Will have to wait for the snow in the alley to melt before I can attempt to clear the abs fault .
Experience talking here. If your ABS ring is dirty and the sensor your light will stay on. Glass cleaner and a rag may fix your problem.
Thank you. When the snow clears, I'll try to clear it by simply riding it. The battery was out. That may be the problem. If that doesn't work, then I'll do what you described. Thanks.
Check to see if the ring is slightly bent this can cause problems with the ABS. Both cleaning and checking for a slight bend is a good place to start. Firm believer in the K.I.S.S. program.
