grampi
Dayton, OH or Joliet, IL
2013 R3R
Is it normal for the ABS light to stay on until the bike is moving? It's the only idiot light that doesn't go off right away after the engine is started...
. . . or until it comes on for good and you need the "Dealer Tool" to bleed and re-set! :eek:
From owner's manual:
"The ABS indicator light illuminates to show that the ABS function is not available. Illumination is normal after engine start-up, and until the motorcycle first reaches a speed exceeding 6 mph (10 km/h). Unless there is a fault, it should not illuminate again until the engine is restarted. If the indicator light becomes illuminated at any other time while riding it indicates that the ABS has a malfunction that requires investigation."
Hope this helps:).
Hope this helps:).
I guess this dummy should read the manual :banghead:...good to know it's normal...
New guy here. 1st Triumph. Bike was delivered last week. Took it out for a couple miles. Parked in garage. It got cold. Took battery out. Charged it in the basement. It was warm enough to get it started and had a check engine light on and the abs light lit also. These were not lit last week. Ordered an obd2 cable to check faults. Any help is appreciated.
