rear light problem ??
Discussion in 'BearClaw Corner' started by albertaduke, Feb 13, 2020.
Tags:
  1. albertaduke
    albertaduke former airline pilot without the big bucks
    Country:
    Canada
    4,184
    Featured Threads:
    139
    Media:
    57
    2,512
    823
    kaleden
    Ride:
    2013 roadster
    what could cause the rear position light to stay off when the ignition is turned on I checked the fuse, I checked the rear led bulb ( brake light works|) it used to work without problem before
    .could it be a glitch when I changed the headlights and reconnected new headlights ?? both old and new headlights are LED and the wiring is fine as well headlights do work on low and high.
    I am sort of baffled or
    am I missing something obvious :mad:
  2. 1olbull
    1olbull Riding Motor Since 1950
    Country:
    United States
    22,290
    Featured Threads:
    115
    Media:
    5
    19,946
    823
    Tacoma, WA
    Ride:
    2012 R3R "Kong" - 2011 R3R "YurMama"
    Tire rub on wires under rear fender?
    Ishrub and Boog like this.
  3. albertaduke
    Country:
    Canada
    4,184
    Featured Threads:
    139
    Media:
    57
    2,512
    823
    kaleden
    Ride:
    2013 roadster
    nope.. I checked that and not only wires are solid but I installed some time ago a metal plate covering the wires entering the fender just to protect the wires from rubbing and there are no rubbing tire marks on that plate either .......mystery deepens .....at worst I will tape a bicycle light over and above the red cover just in case I ride at night
    Boog likes this.
  4. Joesmoe
    Joesmoe IMOKUR2 Staff Member
    Country:
    United States
    4,389
    Featured Threads:
    50
    Media:
    7
    6,069
    823
    Fairfax, Virginia
    Ride:
    Triumph: 2014 Rocket III Touring
    I had problems with my turn signals and it was a function of a crappy design of the socket. The contacts are free floating, and putting a bulb in blind there is a good chance the tab will be jammed and bent away from the bulb contact.
    TURBO200R4 and Steel like this.
  5. Boog
    Boog Traveling Story Teller
    Country:
    United States
    5,724
    Featured Threads:
    57
    10,712
    823
    Dumfries, Virginia
    Ride:
    2014 R3T, TORs,
    If it is not the wires (I had that problem last year) and its not the bulb (I have had that problem multiple times) Could it be corrosion inside the housing? I had to have mine replaced once.
    Steel likes this.
  6. albertaduke
    Country:
    Canada
    4,184
    Featured Threads:
    139
    Media:
    57
    2,512
    823
    kaleden
    Ride:
    2013 roadster
    please no..... this mean I have to remove the metal plate remove the wires the
    the bulb is ok as the lights come on when brakes are applied I think there is something to do with wiring somewhere .... my worst nightmare I hate playing with wires and connectors what if I was to pull the 20 amps fuse turning off the headlights would the rear position light remain on or not depending on that I could narrow the problem down Maybe ..
    Joesmoe likes this.
  7. barbagris
    barbagris Mad Scientist
    12,278
    Featured Threads:
    57
    Media:
    85
    12,900
    823
    On the verge of insanity
    Ride:
    2009 R3-Standard - 1979 Guzzi V1000G5
    Patrick
    The MULTIMETER is your friend. Check the contacts.
    TURBO200R4 and ant like this.
  8. albertaduke
    Country:
    Canada
    4,184
    Featured Threads:
    139
    Media:
    57
    2,512
    823
    kaleden
    Ride:
    2013 roadster
    ok....will try that as well
  9. CamaroCarl
    CamaroCarl Get busy living or get busy dying.
    Country:
    United States
    229
    Featured Threads:
    5
    Media:
    3
    465
    73
    Saint Joseph, MO
    Ride:
    2018 rocket3 roadster
    If it worked fine before you changed the headlights and now it's not working, I think it would be related to that. Pretty sure it's the same circuit. When I changed to leds I didn't have any problems, but I think some people have had to use resistors. Maybe the new headlights draw less current. I'm not an electrical guru, just throwing out ideas.
  10. barbagris
    12,278
    Featured Threads:
    57
    Media:
    85
    12,900
    823
    Ride:
    Pat - This may sound dumb - But you changed the headlamp. What about the parking light connector? IIRC the tail light and Parking light are on the same circuit.
    TURBO200R4 likes this.
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
