barbagris
Mad Scientist
- Joined
- Aug 1, 2010
- Messages
- 12,988
- Location
- On the verge of insanity
- Ride
- 1979 Guzzi V1000G5 - 2018 KTM 790 Duke
Guys
I've been playing about with Intake Air Temps. And re-discovered (Wayne Tripp told me about this ages ago) there is a HUGE amount of hot air drawn up into side mounted air filters originating from the Radiator. I've discounted LOW SPEED temps - This is all based on numbers at 80-90mph.
With a Big open side mounted filter I've had the worst results of all - Intake Temp over 20ºC higher than Ambient.
Best has been with the RamAir stage one AND Les's OZ Claw and adding these small deflectors - 6ºC
In my case I suspect fork lowers cause SOME turbulence maybe pulling some heat into the scoop inlet - But the HUGE difference come from those two little bits of Plastic. Dropping the temps 10ºC over anything else.
Just thought you'd like the data. I have contacted RamAir so this findings can be used for the (hopefully upcoming) Stage2 setup which be a Claw/Filter/Waterbottle/Bellmouths collection (well that was the plan)
The Stage1 Ramair seals very well against the OZ-Claw amongst the lower edge (happy accident) - I suspect triple RU2780s under a claw will run hotter as they can suck up more from below. But I don't know - and as the AIT sensor is not in airflow with triples it would be hard to compare - so I wont be bothering.
The TORQUE app is your friend. I use it just for logging but ...........................
