I did tire repair for years on construction vehicles to include truck, car, semi-tractor and trailers, 988 loaders and 35 yard rock wagons tires so large you could put a 6 foot step ladder inside towork off of. The plug patch type from the inside are great even though a steel belted cord can cut them the vulcanizing patch still holds. Now the little mushroom plug which can be installed from the outside IMHO is not as good as the fiberous stringy plugs which which will hold up to the steel belts and not get cut by the steel cords. Both will insert on the road side but without being able to buff, clean and stitch from the inside the mushroom plug can get cut fall out on the inside and your flat or loosing air again. I carry the string ones in all my vehicles large and small. One other thing I do noth like in the video or wonder about it the carbide burr on the drill. My thoughts are what is it doing to the steel cords that did not get cut or damaged? Just my opinion also if the mc tire has good tread and not a real large hole it can be damged further especially the bead when removing the tire from the rim. Not saying don't do it but is the price of a say Exedra Max that much to risk it? Car tires are a different ball game but repair well and lets face it are mostly on a vehicle with tree other wheels or more. If I was a member of the LBGTQ/DS community I would still use the string rope? A little humor there guys not meant to bunch anyones panties. Speaking of that my old boss would leave tbe shop whem I would break out the det. Cord to remove a tire from the bead and stay out until he heard me explode the tire back on the rim. If the tire was shot and off the heavy equipment I would just use a 690B track excavator to remove the rubber.
Thanks for that post Warp! Since I already ordered/received my new ExMax (or was it Ex-Lax?) I was not going to turn back from mounting it ASAP - I'm going to try the Ride On sealant/balancer per
@R3Tex recommendation. I was kicking around doing the plug patch from the inside to re-use the tire when the new one wears out, but from what you said here, especially re: the cost of an ExMax ($162.88 + free shipping, no tax @ Rocky Mountian ATV.com) It's just not worth it to me either
BTW, what you said re: "Now the little mushroom plug which can be installed from the outside IMHO is not as good as the fiberous stringy plugs which which will hold up to the steel belts and not get cut by the steel cords" I have found,
through experience to be also absolutely true as in the
3 times that I "picked up a screw"
i used the 'plug n go" mushroom head plug which
did the job for sure, but afterward when I checked them they had a slight leak still. I believe that is due to the fact that they are just a rubber plug (as far as I can tell) with a very thin film of lubricant on them to help push them through the installation tool. The film of lube coupled with not having any rubber cement or any other way to vulcanize them to the tire makes it impossible to completely seal off. So I treat them as a way to get home only product. Then when I got to work the next day I just
easily push the plug through into the tire (I'm sure that helped with tire balance, doing that 3 times!) & re-plugged them with the old school fibrous stringy plugs that will actually vulcanize. BUT, the last hole was too big (again) & that was what I've had spit out of the tire twice
Therefore causing me to order the new ExMax.
Thanks for all the posts Captn's
