Fairchild
Hi! Long time reader - first time writer. - I have taken to thinking of this site as the "Hall of Justice" and you guys are like the superfriends...you have answered so many questions I have had already. You guys are obviously very busy so I would like to take up as little time as possible...
First the overview...I have one of the oldest 05's and would like to upgrade the pipes to Jardines and possibly do something with the airbox...then probably leave it the hell alone. After combing through as many relevant posts as my head can hold I'm still left with 7 questions...they are all true/false or short answer...
1.The PCIII is more familiar to the dealers around here...The tuneboy can do more... For a simple pipe change and possibly an airbox mod....which would be the preferable system for tuning?
2. The Tuneboy "pods" are muy bueno and fit excellently under the bearclaw.... T or F?
3. (If 3 is false)...I would recommend instead...______________.
4. Using the tuneboy edits removes the need to manually remove the secondary TB butterflies....T/F
5. Between the PCIII and the tuneboy I would say _________ has the more accurate "factory map" (of the configuration I'm thinking of).
6. Clutch plates can be glazed badly in as little as 1000 miles, especially if you try a lot of wheelies. T/F
7. Dyno tuning is essential for every bike using the setup above... T/F
Thanks guys for any help in advance. I hope someday to advance to the level of "Wonder Twin" (at least that guy who turns into the bucket of water).
