Rocket Scientist
Grand Exulted Poobah
- Joined
- Sep 27, 2009
- Messages
- 6,851
- Location
- Spring Lake, Michigan
- Ride
- Black 05' Rocket III standard
Starter tight, no cat, drained diff onto a magnet wrapped in white cotton, no swarf. Removed rear wheel cush drive and bearings all good.
Removed diff looks good. no end float and back lash seems acceptable. Spline was rusty brown which amazed me as my tyre is only half worn and I put lots of Molycote on it when I do it.
Will replace all the wheel bearings.
Probably remove the swing arm tomorrow to check movement in damper shaft if I get time to make a lifting attachment for my trolley jack at work tonight!!!
I read somewhere here that Avon tyres make a bit of noise when they are worn it couldn't be that could it? noise mainly happens at 120kph and sometimes when decelerating at around 50kph.
Tyres wear very flat around here as we have very straight roads.
Used moly looks like rust. Kinda disturbing the first time you see it. Perfectly normal.
