So here's the design, free to one and all.
I've brought it this far, feel free to go get someone to make it for you.
This was demonstrated to work in a prototype/proof of concept way, so it isn't perfect, but it's 95%+.
Needs a gear manufacturer and a guinea pig to finalise.
It's been a few years so hopefully I haven't forgotten anything pertinent, or mixed stuff up any.
The secret/trick was using the same gear pair as 3rd, but in reversed positions.
I.e. 3rd is 23T input and 33T output, and this 6th is 33T Input and 23T Output.
The principle was beautiful in its simplicity really.
The rest was about fitting it all together.
This is quite overdriven and will result in cruising at a touch under 2200rpm in 6th at 80mph, as opposed to over 3000rpm in 5th.
Will raise top speed potential (i.e. provided you have the power to get there, or are on a dyno where there is no wind resistance) to 220mph at stock 6300rpm, or 320mph if you spin the motor to 9000rpm.
Gear Ratios
Primary 1.034:1
1st 2.929:1
2nd 1.947:1
3rd 1.435:1
4th 1.160:1
5th 0.964:1
6th 0.6969:1
Secondary 1.043:1
I'm sure there are more interesting tidbits I've forgotten.
Parts List
0. Heavy Duty Wider & Deeper Groove Circlips
1. Input 3rd & 4th Gear
2. Input 6th Gear Splined Bush
3. & 4. Input 6th Gear Splined Washers
5. Input 6th Gear - 33T Straight Cut Spur Gear
6. Input Shaft inc 14T integral spur gear
7. Output 1st Gear (modified existing)
(-1.0mm off front face, -3.45mm off front face of centre boss)
8. End Washers (2)
Input 2nd Gear End Washer M30x42x1
Output 1st Gear End Washer M25x35x1.5
9. Output 2nd Gear (modify existing)
