bruce aussie
WOODENBONG
To check if your steering head is to tight jack it up with the bikes standing up straight and the front wheel about 100ml off the ground. Hold the front end in the middle and let it go it should just fall away gently to either side under its own weight. It might need a little tap with your hand to start it moving from centre but then if it doesn't fall away to the stop there too tight
