Looking Good Man
To work and back today (no snow) without incident. I was betting on the the TPS but it turned out, pretty sure, to be the POS (stepper motor) - the appendix of the Rocket 3.
It took all of maybe 10 minutes to disable it. For those who may come later looking for details....
- Remove the tiny cotter pin from the stepper motor and the two washers. Remove the two screws that hold the stepper motor to the throttle bodies and the electrical connection. Slide the stepper motor off the shaft. Unscrew the small nut at the bottom of the SM and remove the linkage. Reinstall the SM with the two screws and reconnect the wires to the SM.
- Remove the number one K&N filter, or equivalent. There you’ll see a nut with yellow paint. Use a 7mm open end to loosen the locknut and a 2.5 hex to turn the bolt clockwise to establish the proper idle speed. Tighten the locknut.
- Life is good.
Original photo by @1K9
Now when it’s cold I will have to add some throttle before the bike warms up (back of wrist to forehead - Ronco commercial)
