Kevin frazier
Widowmaker!
I believe now on a roadster you can unplug or just turn off in tune ecu, that was toldto me alain added that feature for roadster, if not just unhook linkage from stepper to where it attaches and yes you eill adjust idle, that screw has yelliw paint and if you pay great attention marking exac where it is so if it is the stepper you can order another and put everything back exactly as factory. Also if you just disconnect linkage there will not be a code. But you will know immediately if stepoer has indeed gone bad.I didn't check the gap- have in the past. Easy to do and will check in the morning. So, just unplug it to disable, or also remove some linkage- I haven't really looked at it to see how it operates yet. Once done I need to set idle manually, right?
