Victory rear view mirrors?
Course if you put these on your Rocket, it will run slower, rattle at idle, and the mirrors will fall off while you're riding.
And you won't be able to see jack**** behind you ... maybe stick with the Triumph tear-drops .
I installed the Triumph black teardrops on my Roadster a couple weeks ago. I really like the look and I'd rate the visibility as adequate. The stems are about 1/4" too long but I took care of that with a handheld pipe cutter. Now I can move them where I want them and they stay put!
I went with a pair of somewhat older mirrors....like from the 50's.....
I am thinking about installing a rear view camera wide angle lens with a 7 inch screen right above the headlights behind the windscreen it should cover all the rear, and clean up handle bar.
am I the only one thinking about this solution.
I imagine a rear view camera and screen could work really well. However, as I'm very happy with my Triumph ovals - good visibility and no vibration - I don't feel I have a problem that needs a solution.
That would be awesome, especially if you could record from it. Of course, I'm sure there would be mostly video of frowning riders on Harleys trying to catch you...
now ..never thought about that but it is quite the incentive to do it just to see the squirming faces on hardly- dimension. looking into it this week-end
