Tire Pressue
Mine are set fit 42 front 46 back, these are from a note in the specs from Metzler 880 XXL for 2up light, there are other values for solo and 2up heavy. There quote about these pressures equal better mileage/tire life.
Always inflate tires to the correct pressure as indicated in the owner's manual. However Metzeler North America has found the air pressure suggestions listed below will improve mileage and customer satisfaction especially if a emphasis is placed on running the air pressure towards the maximum as stated on the sidewall. Check cold tire pressures frequently. Correct tire pressure is crucial for safe handling. Over inflation may impair ride comfort and reduce the contact patch between the tire and driving surface of the tires. Insufficient air pressure will result in poor handling and cause a tendency for the motorcycle to "wander". In addition, improper and insufficient tire will cause accelerated tire wear, increased fuel consumption, less control and the possibilities for tire failure to due an overload/under inflated operating situation.
Recommended Minimum Tire Pressures (PSI)
Touring/CruiserAlpha ME880 (MH, MT, MU tires)Solo2 Up Light2 Up HeavyFront364040Rear384040
ME880 Solo 2 Up Light 2 Up Heavy
Front 38-40 40-42 40-42
Rear 44-46 46-48 48-50
For bikes with the following rear tire sizes: 170/80-15, 180/70-15, 150/80-16, 160/80-16, 180/60R16, 180/70R16, 200/60R16, 240/50R16, 140/80-17, 160/70-17 D spec, 170/60R17, 210/50R17, 150/70-18, 180/55ZR18, 200/50R18, 210/40R18, 260/40R18, 280/35R18, 300/35R18, 260/35R21.
