Final post in this thread regarding tuning, I have made a couple of rather interesting discoveries that I haven't seen documented elsewhere yet:
1) I am not sure if this applies only to the new ECU bikes, but, when you run a gear out to redline and let off completely from the throttle, the motorcycle has a "decel fuel cut" function that completely cuts fuel until RPMs come back down to 3000. It cannot be tuned out, it will fully cut fuel when the throttle is at 0%, map is below 250hpa, and RPM is over 4000. It's not a problem, but it does mean that you cannot ever completely tune out decel popping, there will always be at least 1 pop with an open exhaust coming down from high RPM with the throttle closed, it will pop when going from decel fuel cut back to fueling and the exhaust passes through the magic ratio required for ignition in the pipe.
--Not really a big deal, but interesting to see they either added this to the ECUs or no one has ever mentioned it before that I have seen.
2) The second interesting discovery is accel fuel enrichment. No matter what I do with F or L tables, when you move the throttle rapidly, causing a spike in MAP the ECU compensates by dumping some extra fuel. It puts the AFRs in the 10.8-11.0 to 1 area for a split second when doing a 30% or more rapid TPS change. With fast but only slight openings, it will dip into the 12.5:1 area then go back to fueling normally. It is proportional to the amount the throttle changes, very small but rapid changes induce smaller, but repeatable rich conditions.
--I am actually pretty impressed they managed to work this into the ECU. I don't really like "how" much fuel it adds with big changes, seems a bit excessive to me, but at least there is an accel enrichment function. Also thought I would mention this as I have never seen anyone document it before.
GL/HF tuning, don't blow stuff up
