JP just so you know Carpenter was most likely talking Tune Boy for the higher rpm map. There are custom Tune boy maps that run up to 9000 rpms. No that you need 9000 rpms but running a stocker up to 7400 is not out of the question. The PCV will override any limitations put on the injector pulse width ratio set in the ECU which neither tune boy nor tune ecu can re program. I am not kicking tune ecu just wanted you to know its limitations other then that it is a fine program. Especially for the price
I also just noticed you have a 2015 so I can not speak to whether Tune boy has built a custom map yet for it. Or if it is any different from the 2014 programming. If they have it the new tune boy also incorporates a Innovate wide ban controller and wireless link up to the ECU. Its a wee bit pricey but has a lot more goodies to play with.
