Tune ECU - Tors - Cat delete - Ram Air
HIM57
.040 Over
Rancho Cucamonga, CA
2008 Triumph Rocket 3 Classic
Hi,
Got the above going on and loaded a tune that seems to work well with this combo. Just wanted to confirm as I am new to Tune ECU does this show that the secondaries are open 100%?
Thanks
I have that set up and use the same tune 20228. However mime has been dyno tuned. The dyno tuner said my copy of it was really bad as it was for this setup. He had to change the tune because it was way out of spec in fuel and timing.
Has your copy of the tune been tweaked for this setup ?
Not modified at all - seems to run OK but have you any more specifics? A little worried now!
