utogitorogi
Standard Bore
triumph rocket 3r
Good day. Need help. Wondering what I'm doing wrong. Last flash with Tune Ecu failed and from there can't recover my ECU. Been doing the connect then cancel thing, until the full reprogramming option shows up, click on it then continue. Reprogramming level shows up then fails. Nocco charger, OBDII MX, Voltage constant 12.6 and pulled the headlight fuse.
Tape the fob to the LHS of the rear grab bar, so it's close to the antenna. Read instructions well 🙂. Open an unaltered stock file and see if you can recover the ECU with that first. Good luck
