So I left the stepper on, cleaned it and sprayed it. But when using the TuneEcu, to get to the correct voltage, I have to loosen it until there is no tension on the spring, and its a little loose. It wouldn't idle turned all the way out (with the correct voltage) so I tightened it back until there was tension back in the spring and it idles fine now but its outside the proper voltage range. I have the one on the donor engine and I will most likely swap it out tomorrow afternoon if its still acting up tomorrow to see if that fixes the issue.
Yes, the TPS seems to have helped. The old TPS would only read down to 2 or 3% even after I tried to set it multiple times.
