Tranny Rebuild
There's also a ****-tonne of play in the drum grooves for the fork lugs to slide through ... in fact I'd go up a level in adjectives and call it slop rather than just play
This is the problem with trans issues. At times there is almost zero visual differences between one that works fine and one that doesn't. Years ago I made an air shifter for my dad's 900 Kawasaki drag bike. The air cylinder I used was a couple milli seconds to slow. I made about 10 successful runs with it, then one time, it failed to engage 5th gear. After that it didn't want to go into, or stay in 5th gear. Upon year down and investigation, you could barely see any damage to 5th gear. A friend of my father re-cut the dogs and it was fine after that. The long winded point of all this is just the slightest wear /damage to the engagement dogs and the trans goes from working great to not at all.
Did you check the tolerances on the fork to for groove and the drum grooves along with the pin diameter and clearance in the drum grooves? Just thinking out loud. Also wondering about the drum bearings anong with drum concentricity?
