Well got TPS set to .63 that was as low as I could get it. I read that rocket scientist has his set at. 65
Now to get. 72 on the ISCV nut
7 mm combo wrench you can get at it with the box end. There is a little plastic cover on the cable wheel two 8 mm bolts. After you complete the ISCV hit reset adaptives let it do its think then turn the key off count to 5 and turn her back on with the fuse in and she should fire up. Did you add a new tps or clean the original one?
7 mm combo wrench you can get at it with the box end. There is a little plastic cover on the cable wheel two 8 mm bolts. After you complete the ISCV hit reset adaptives let it do its think then turn the key off count to 5 and turn her back on with the fuse in and she should fire up. Did you add a new tps or clean the original one?[/QUOTE
Hi Warp9.9
I have turn the nut all the way in and the voltage did not move at all.
Bloody hard with engine crash bars too no room quarter a turn at a time if your lucky.
Has me worried the the thing could be buggered.
The TPS I only cleaned it. cost for a new one in New Zealand is $249.00.
Been out here for 4 hours and not any closer to getting her to run right.
This is the thing I wound all the way tight and undone again as no movement in volts.
What did I do wrong?
Well had another go and nothing changed. Fire it up and now revving 4000 - 4500 range.
Will get machainc / auto elecriction guy to fix hopefully..
Will let you know how that goes.
this might help you. its not only Rocket specific but has the stuff for the rocket in it
http://www.tomhamburg.net/Tunes_in_...C_Stepper_Adjustment_A4Rev_02_20120204_EN.pdf
Some where I had posted the steps on this site this year but I have note found it yet. Someone might come along that saved it.
It's amazing how time flies and you can't find posts and documents that were more important than air last week ! I memorized your instructions and then ate my phone !
If .63 is as low as you can go then you have the primary TPS installed wrong or its knackered up. You should be able down in the .5 range when adjusting it.
