Ran this tune with TORS and RAMAIR and PB crosssover pipe and bike runs great but a little concerned about seeing AFRs running past 15 around 2800rpm? Is it safe to run at those values? I had thought that it’s better to run something under 14.5?
do you have an afr gauge or did you get a dyno baseline with a sniffer? running past 15 how far past 15 and how bout the other areas of the map. From what ive learned the rocket can handle 15 is it ideal no but i was told its not gonna hurt it, just lean up there at cruising highway speed sounds like, i assume you were talking about 5th gear 2800?
do you have an afr gauge or did you get a dyno baseline with a sniffer? running past 15 how far past 15 and how bout the other areas of the map. From what ive learned the rocket can handle 15 is it ideal no but i was told its not gonna hurt it, just rich up there at cruising highway speed sounds like, i assume you were talking about 5th gear 2800?
Running a Dynojet pod-300 with the wideband o2 sensor
it’s runningover 15 on a few occasions out to 16 momentarily in 3-5th gears anywhere around 2800 rpm... slightly dropping or increasing throttle drops the afr back to 13-14something.... there is a band that just runs real lean and it seems to be the cruising throttle range ..... not sure I wanna run for an hr at a time somewhere between 15 and 16
You’re probably gonna get good fuel mileage, when i put that tune in claviger told me the bike could go that lean and be ok, and i ran that way for quite awhile,
Yes I could I guess.... I have temporarily set an afr of 13 on the autotune and it cools the beast down.... I can get a tuner to tune with the pcv but don’t know anyone that works with tune ecu
