EasTexRIII
Nuff said. I started a conversation with you and included my email.
One more question. I recall reading somewhere that the 12 minute tune is more or less useless to do if I have the O2 sensor removed. Is that what you understand to be the case?
No, you need to run the 12 minute tune at the end of all your "resets" (reset adaptives)- it helps level out the idle..... OH, that reminds me, when you get that tune, go to the idle settings and set the idle tables at 925-950 so that oil will properly circulate while sitting still at stops - low idle does not properly circulate oil! Also on mine, I set the speedo correction at -2.5 to get correct speedo reading (you may have to experiment with yours) - Save those settings & rename your new tune
